Ampeg SVT oddity
  • Ampeg SVT oddity
    I came across something odd last night at a gig. Ive been in live sound for many years and Ive never seen this......
    Rack mounted SVT Pro 3 . I was using the Xlr out and strangely , the Xlr out level pot on the back was controlling the amps volume out of the speaker cab . The pre/post switch on the front didnt change anything.
    This has got to be a fault with the amp yes ?? Anyone ever seen this ?
    Do you have a schematic? I'm having trouble finding anything other than the power amp schem.
      Very odd... That level adjust is a pull switch to lift the ground. I wonder if there is something funky happening with that switch shorting something?
      Manual - SVT_3PRO_OM.pdf
      Schematic - SVT_3Pro_Schematic.pdf
        Originally posted by TomCarlos
        It looks like this one is the Full Schematic and Board Layout - [ATTACH]n985479[/ATTACH]
        Although the file is named 3 Pro that seems to be the schematic for the SVT III, which is totally different circuit I believe.
          Thanks Glebert... I deleted that post with the full schematic.
            ok...i have the exact model wrong. the model above looks slightly different.. Ill ask the owner. It looks very similar..i know its an older amp
