Hello Y'all, I have a Gv-22 (https://ampeg.com/support/files/Sche...0Schematic.pdf) that has an issue- the first channel sounds good, but is too quiet!
Information so far:
1. Qualitatively, the channel sounds good, rich, and like a guitar amp should. It's just %60-%70 of the volume it should be, and I can compare it to another GV-22 to confirm this. Channel 1 is the tremolo and reverb channel.
2. I scoped the signal coming out of the tone stack on both channels and it is identical, so we know that the signal loss happens somewhere AFTER
the tonestack on CH. 1 and (Edit
the summing point "Z"
Things I've tried;
1. Replacing all the caps (except the .002's since I have none) and verifying all the resistor values in the tremolo section.
2. Measuring for incorrect Voltages, but they are in line with those posted on the schematic, and swing with the foot switch on / off. as they should.
3. The tremolo and the Reverb work just fine.
Anyone ever experience this before, or have an idea of where the signal loss could be occurring? Happy to provide measurements, but again, voltages all match the schematic through that section.
Thanks!
P.S. So nice to see the forum up and running again!
Information so far:
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Things I've tried;
Thanks!
