I see the guy in Psionic Audio uses this and at this price ($349) I think my boss will spring for it. Can I use it right out of the box to troubleshoot amps? Or do I need special probes etc?
Rigol Ds1054 Z o-scope.
Are you sure you need 4 channels? Readouts with 4 channels can be confusing.
I think with analog circuitry 2 channels are sufficient.
I like to have 2 channels (e.g. to see phase differences between signals) but I rarely use the second channel of my Siglent SDS 1202X-E (love it).
New scopes typically come with a set of probes allowing measurements up to 400V peak.
For higher voltage points you need an x100 probe.Last edited by Helmholtz; 09-12-2023, 10:14 PM.- Own Opinions Only -
- Likes 1
There are actually 2 voltage limits.
One is for the scope input, the other for the probe.
A voltage divider after the probe cannot increase the probe's limit.
A 1500V probe needs to have larger leakage and creepage distances and use materials having a higher dielectric strength than a 400V probe.
Probing power tube plates is best avoided because voltage peaks can exceed 1500V in extreme cases like with oscillation.Last edited by Helmholtz; 09-13-2023, 04:00 PM.- Own Opinions Only -
I hardly know anything about o-scopes. When I took my tech course back in 1980, the teacher showed us you can inject a signal and use the scope to trace along the circuit until you see no signal or one that is weak, jittery etc. I have been able to fix quite a bit by looking at the schematic and figuring out which component might be defective or from guidance from guys like you. But we have a few amps where I can't figure it out and will have to trace and see where the signal goes awry. But now I want to look into that Siglent.
Rigol and Siglent specs and prices (over here) are quite similar.
I just liked the display and readouts on the Siglent better.
I typically buy from online dealers offering money back after 2 or 3 weaks testing.- Own Opinions Only -
Originally posted by rockman627 View PostJust to be sure, is " waveform generator " the same as "signal generator" ? I'd hate to get this and then tell my boss I need a separate signal generator.
I'm sure there's a model having that feature.- Own Opinions Only -
FYI: Though I have a signal generator, it's often easier to use YouTube test tones. You can find just about anything you need, from single frequencies to sweeps to isolated guitar tracks, etc. Easy to switch from one to the other. Just run a line out of your PC sound card, or even a phone/tablet."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
A waveform generator can be a different device to a signal generator; a signal generator usually allows the choice between fixed waveform types (mine just does sine and square), but a waveform generator can produce user-defined, custom waveform shapes in addition to standard types. Also numerous modes of operation.
Originally posted by Mick Bailey View Post.... but a waveform generator can produce user-defined, custom waveform shapes in addition to standard types. Also numerous modes of operation.
I use a "Function Generator" providing sine, square and triangular signals. All 3 waveshapes are useful for amp testing.
