Hi all!
Here Debe writing from Italy!
I Have a Fender 112 Plus which was used in a music room in my town.
I think it's not worth repairing it in a service center, so I tried myself but I get stuck...
Here's what I've done:
Thanks in advance
Bye
Debe
Attachment: Fender service manual I found on the net.
- Changed C47 and C48 with similiar capacitors (same spec but smaller in size);
- Resoldered R67 and R68 because of burnt trace on pcb (they get very hot when power on);
- Resoldered CR26 and CR27 for the same reason;
- Resoldered jack in (each) and poweramp in;
- tested power rails on TP3-4 and TP5-6: TP3-4 was 42v instead of 39.6 as in attached schematics. Each rail stay constant while changing volume
- applied a 1khz on input 1,2: preamp seems working (I can see a signal on preampout and also on the spk out).
- same signal applied to poweramp in. Here's come the first anomaly: I have to bend the stereo jack a bit to see signal on output (that's why I resoldered it unfortunately without success).
Thanks in advance
Bye
Debe
