Marshall Valvestate VS65R Channel Two Out
  • Marshall Valvestate VS65R Channel Two Out
    Starting to debug this amp, clean channel works fine, gain channel has no output.
    No footswitch involved, using the front panel channel select switch. When you toggle from clean or gain, there is a loud pop.
    Trying to understand the clean and gain path through the switch. Which ICs are in the gain path.
    Thank you
    Marshall-VS65R-65W-Schematic.pdf
    and this seems odd. IC6 appears wet, like it has sweat on the top of it, which I was able to wipe off. Everything else in the amp is dry
      12AX7 test fine
        The 5201 IC's do the switching (IC 2,4,5). They are switching type op amps. Control voltage at pin1 determines which set of the IC's inputs are used.
        Check that DC is changing on their control pins (pin1), and output is changing at output pin (pin5).
          Clean Channel
          IC2 pin 1 14.3 VDC
          IC4 pin 1 14.5 VDC
          IC5 pin 1 14.5 VDC
          IC2 pin 5 0.1 mVDC
          IC4 pin 5 0.32 mVDC
          IC5 pin 5 19.2 mVDC
          Gain Channel
          IC2 pin 1 13.8 VDC
          IC4 pin 1 13.4 VDC
          IC5 pin 1 13.4 VDC
          IC2 pin 5 0.21 mVDC
          IC4 pin 5 -0.45 mVDC
          IC5 pin 5 13.6 VDC
            IC5 only has CLEAN output
            IC4 only has GAIN output
            IC2 has both GAIN and CLEAN output
            Should all of these ICS always have an input signal present from both the clean and Gain channels?
              So from IC2, for either channel, it goes to the tube. If clean is working, tube is ok. At pin8 of tube it splits off. Ch.1 goes to clean tonestack (VR2,3,4). Ch.2 goes to VR6 and 8, then to IC 6B. Do you have signal at IC6 pin 6 ? From there it goes to VR7 and VR9. If you have signal all the way up to VR9 wiper, IC5 is likely bad.
              Also, you reported DC at IC5 pin5 when ch.2 selected, which further points at IC5 being bad.
              edit: if you do end up needing a 5201 IC, there are lots of counterfeits out there that you want to avoid. These should be legit:
              https://www.amplifiedparts.com/produ...itch-8-pin-dip
                That explanation of the circuit really helps me. Will report back. Thank you
                  In Gain Channel mode
                  I have signal at IC6 pin 6, C55, IC5 pin 6. No signal at IC5 pins 7 and 5.
                  So it looks like a bad IC5
                    Bad ch.2 volume pot (VR9) would also result in no signal at IC5 pin7. You could try desoldering that pin7 and then check if signal appears at the solder pad.
                      Will check that out. Thank you
                        VR9 is open. Ordering a new one
                          Replaced VR9, problem fixed.
                          Thank you everyone!
