1965 Realistic Carnival 6AQ5 Conversion Ideas
  • #31
    I could do a 5K and 10uF cap on the first stage also.
    I do not understand why and how to choose this.
    • #32
      Originally posted by mozz View Post
      Do you think it still needs a input cap or can that be left out if you have a 1meg?
      A tube using grid leak bias always needs to be AC coupled.
      Otherwise the DCR of the PU would kill the negative grid bias caused by the tiny grid leak current.
      • #33
        misterc57:
        Please post an updated schematic showing actual wiring, component values and voltages (including plate and cathode voltage if applicable).
        Do you still have a hum problem?
        • #34
          misterc57:
          Will do. No hum
          • #35
            Updated schematic. New voltages are in red. Original values in black
            • #36
              What are the voltages at the far ends of R5 and R8?
              Acc. to original schematic they would have been connected to the same 100V power supply node.
              • #37
                No input cap. Either you need 1 or convert totally to cathode bias, no in between.
                • #38
                  212V. Yes they are connected together at node 3 of the filter caps.
                  Updated schematic attached.
                  • #39
                    Sure I can convert to cathode bias like the other triode. 10uF and 5K
                    • #40
                      I recommend to use a 1.8k cathode resistor and a 47µ bypass at the input triode for best center bias and low heater buzz.
                      • #41
                        Installed. Only had a 1.9k. All V are up. Should the plate V of 6AQ5 be lower than the pin 6 grid?
                        Thank you!
                        • #42
                          Plate voltage being a few volts lower than screen voltage is no problem.
                          That's not uncommon.
                          Also with signal plate voltage is generally much lower than screen voltage most of the time.
                          • #43
                            On the output transformer the schem shows blue to 4 ohms and yellow to 8 ohms. However the factory wiring is opposite that acc. to the speaker terminal designations on the chassis.
                            I see the following resistance
                            black to blue 0.55 ohms
                            black to yellow 0.43 ohms
                            Can you tell which is which based on the readings?
                            • #44
                              Usually the lower DC resistance is the lower impedance tap. So the factory wiring rather than the schematic should be correct.
                              • #45
                                I will post final pictures and final schematic when all is done.
                                I am very happy with the sound of this amp! Very pick responsive and guitar volume responsive with the perfect amount of saturation.
                                I had the 6V6 version of this amp a few years ago and felt the same way about that one.
                                The bass control is subtle. Treble control is very noticeable. I am using the original 500K pots.
                                I have installed an internal 1A fuse. I still have to install a 3 prong AC cord and a back plate for the output jacks.
                                The indicator bulb does not work. It is an odd one. Does not look like the front part lens can be unscrewed. There is a nut inside the chassis that holds the assemble in place. Anyone familiar with this type of assembly and bulb? Pics attached.
ID:	986876 Click image for larger version
ID:	986878 Click image for larger version
