Sencore MU150 Continental Ii
  • Sencore MU150 Continental Ii
    Looks like Grid Leakage, Dynamic Mutual Conductance, Life test, and GM test button functions not working on this tube tester.
    It can't be much as it is a very simple machine.
    Have you checked T2 for output? Click image for larger version
Name:	Screenshot 2023-10-24 at 13.07.17.png
      Here some photos. Not sure of test points.
        I just repaired a TT-1 Heathkit. Gm function would work on it either. Turns out the 2 tubes in it were worn and wouldn't oscillate for gm test. The switches may need to be worked some also.
        nosaj
          T2 leads going to Filament(A) switch, not reading per schematic. OB2 tube not lit(cold). 12AU7 is lit.
            OB2 is a cold cathode regulator and lights when the threshold is reached. I would hazard a guess, T2 & T3 are not being powered up. (8.2v zener has no voltage to supply the transistors).
              These two (2) diodes measure ((-)mvdc) and (.258v) diode test.
                With one leg lifted?
                nosaj
                  Germanium diodes measure abount 0.25v one way and almost infinity the other.
                  If they are CR9 & CT10 then they allow the multivibrator to trigger.
                  Check you have 8volts across the zener. CR11
                    nosaj
                    No, measured in circuit.
                      Yes, the board is stamped CR9/CR10. Getting ((-)mvdc) across CR11.
                        With no voltage across either, the transistors are no oscillating.
                        8 volts on the supply?
                        Check the main power on the anode of the OB2, if no voltege, check the switch contacts and supply to the switch and follow the circuit back until you find the AC power from the transformer.
                        One of those is missing.
                        Discover which one and repair it.
                          Correction: Shorts, Gm-Emission, Grid Leakage functions work. Dynamic Mutual Conductance function does not due to Gm Test switch broken. Need to know where to get that Gm Test switch from?
                            Lets have a picture of it. The backside.
                            nosaj
                              nosaj
                              Backside of the Gm Test switch? There are photos in this post of board and front of unit.
