SWR Strawberry Blonde popping noise turn on /turn off
  • SWR Strawberry Blonde popping noise turn on /turn off
    I have a strawberry Blonde that makes a popping noise when turning/ on or off. I see that on the web it says that this is normal however the customer says it it now more pronounced. I have 2 questions
    1 How do I determine which revision i have to find out what schematic I need?
    2 The popping noise is it related to the power switch or the power supply and what might one be able to do about it?
    Thank,
    nosaj
    Sounds like a mains issue.
    I would fit a 4n7 class Y capacitor across each mains switch contact and a 100n class X across the mains before the switch, to act as a snubber and stop any interference.
Name:	Screenshot 2023-10-28 at 21.06.16.png
ID:	989348 How could i implement your suggestion with a SPST switch?
      Thanks,
      nosaj
        Nevermind I got it. 100 nf across IEC connector and a 4.7 across switch. Noise gone. Thanks a bunch Jon
        nosaj
          Hi Jon, how did you come up with those values?
          Thanks,
          nosaj
            They are the values I have used, over the years.
            100n class X sits across the mains to filter out most of the mains borne interference and mains spikes, caused by the on/off switch.
            The 4n7 class Y is to dampen the HF from the contact bouncing when switching in either direction.
            Of course, a single pole switch, only requires one 4n7.
            Pleased to help.
            Jon
