Marshall G80RCD Loud Squeal OD1 and OD2
  • Marshall G80RCD Loud Squeal OD1 and OD2
    Hey Folks
    Just installed a new proper 6 pin input jack on this amp.
    Clean channel works fine. OD2 has a horrible squeal as the Gain Pot is turned up. OD1 also but not as bad as OD2.
    Any suggestions?
    Thank you, MC
    Marshall+G80RCD-G100RCD.pdf
    There is a possibility that the jack socket has a bad ground or even inserted 180° the wrong way around. (Yes, I've seen it a few times).
      Turns out the main issue is a bad Gain pot. A lot of dead spots even after disassembly and cleaning.
      A few other pots need to be replaced as well.
      Thank you!
