Posted this to alt.guitar.amps but don't think people actually talk about amps over there anymore so figured i'd try here too...
One day during practice my mid 70's SVT head started distorting and I
could see at least one glowing red tube, so I shut it off and put it
aside until I could find some time to fix it. That was 2 years ago.
Now i've decided I really want to get her going again so I cleared off
my workbench and opened it up. Found that one of the caps in the plate
supply for the 12DW7 had high ESR and the resistor following it was
toast. Unfortunately the cap was part of one of the multi section
cans. Some of the other filter caps were starting to bubble so I
decided its probably a good time to change all the filter caps.
Changed everything out. Replaced the toasted resistor. Quickly checked
through the other resistors in the power section and everything seemed
ok. Put it back together and brought the voltage up on the variac.
Everything looked good so I put the Svetlana 6550s back in. They are a
few years old but haven't seen heavy use. I set the bias and the amp
works but after a few minutes one of the 6550's starts to glow red
hot. I swapped the tube with one next to it and the red glow followed
the tube. I'm just a hobbist with enough knowledge to get me in
trouble and this is my first time working on an SVT. My two questions
are did I overlook anything obvious? And second, since I assume the
glowing red tube is toast, do I need to buy a whole new set of matched
6550's? Is there a way to get another Svetlana 6550 that would match
my set? Tossing these would be a shame since they are $$$ and these
haven't seen much use.
Thanks in advance for any help.
-Randy
-Randy
