This amp is reported to have the following issue: Channel 1 only- as the gain pot is turned up volume increases normally until approx 1/3, then as it is turned up past that point rapidly decreases
in volume. Past 2/3 gain on the knob begins to increase in volume but only slightly. Tubes are all Mesa brand and tested good. Gain pot removed and tested good. Also removed pot cover and looked good. Cleaned pots. Tested filter caps for value & ESR-good. Checked resistors in Ch 1 area. Noticed some transformer goo dripped out of PT, not much but a few drops. Read another post here and was talking about DC voltage present on the gain pot leg opposite ground leg. Checked and shows between 28-37 volts DC on same leg. Removed preamp tubes 1 at a time and did not change the voltage present. Note this voltage is only present with the standby switched to play or on. Otherwise the amp works fine. Schematic attached is preliminary
boogie-dualrectifier-3ch-solo-head.pdf
