A guy brought me a JCM800 that burned a few power tubes in one socket but not the other. It burned the socket pretty badly, so I changed it.
I suspect maybe the OT. But my initial measurements show that it may be OK. With no tubes or load, the SEC has 1 ohm of resistance, the PRI has 89 ohms. It is show 5-4M ohms from PRI to SEC. I compared it to a Fender OT and got similar readings.
With a tube in one socket it powers up and acts normal, even passes audio at a strong level. With a tube in the other socket the amp hums loudly, smokes the tube beteen pins 2 & 3 and blows the HT fuse.
The voltages are the same between the 2 sockets (no tubes)
1 - 4.6VAC
2 - 614VDC
3 - 618VDC
4 - -51.4VDC
5 - 622VDC
6 - 4.5VAC
7&8 - GND
I have a schematic but there is no voltage reference info on it.
Any help would be great.
Thanks,
Mike
1 - 4.6VAC
2 - 614VDC
3 - 618VDC
4 - -51.4VDC
5 - 622VDC
6 - 4.5VAC
7&8 - GND
Thanks,
Mike
