Good day and merry Christmas everybody :-) .
I have an old Gibson vintage amp (that I DO love) that is labelled GA-18.
Actually its circuit matches perfectly (except for the filter section) a schematic labelled GA-16T (attached) instead of the one labelled GA-18T (also attached). So let's stick to the GA-16T schematic.
The amp has got a 20+20+20+20 uF @450V multisection cap in the power supply section, with two of the positive lugs soldered together (see attached photo_1). This latter joint goes to the 470R resistor and to the OT center tap.
First question: is that a parallel connection? What are the final capacitance values of that can cap? 20+20+40 uF? Or is that a series connection yielding 20+20+10 uF?
Now the main problem and second question:
The GA-16T schematic calls for 20, 10 and 10 uF filter caps. Why that increased filter configuration in my amp? I believe that the Rubycon can cap (see attached photo_2) is a replacement unit from previous maintenance work - maybe someone decided to change the original filter configuration? Does it make any sense?
For completeness of information, a few years ago I replaced the original tiny output tranny with a 15W Hammond 1750E tranny meant as a replacement for Fender 5E3 Deluxe amps.
The amp sounds gorgeously, maybe cleaner than expected for an old 15W tube amp. I am thinking of a cap job just to prevent possible failure of the old electrolytic caps in there (the bypass caps are old silver-coloured Spague units), although the can cap date stamp might suggest a 2008 (?) manufacturing.
I am wondering what filter caps should I install.
Thanks in advance,
Carlo
Thanks in advance,
Carlo
