This fender blues jr had a broken fat switch. One of the low voltage caps c34 was bulging. So i replaced it and the fat switch still didn’t work. Then i finally took a measurement of the voltages and found the negative voltage is around -7 or -8vdc. I replaced the zener diode thinking that’s got to be it, and still no change. Even though the reverb is working with the lacking neg voltage i thought that something might be dragging it down, so I changed the IC. Still no luck. D5 has the required -26vdc. One side of R53 has the -26.8 but the other -8vdc. R53 measures 739 ohms the other one R50 750 ohms. Do you changing R53 would take care of the problem?
Blues jr low voltage problem
Which version of Bj? Mk1, 2. 3 or 4.
I don't think replacing R53 will do it. If it measured OC then yes but it is a resistor and roughly the correct value.
With the IC out, what voltage did you get?
Is C34 the correct polarity and did you use the exact value?
I didn’t think to take a voltage measurement with the IC out. What seems counter intuitive is that r53 is lower in resistance, so i would think that the voltage would be higher. Anyway I had to order some 1 watters. Only have half watt ones. Thanks. Oh and the cap is in right with the correct valueLast edited by pontiacpete; 12-26-2023, 03:44 PM.
There is only two places the -15v goes to; pin 4 of the IC and R57 on the boost switch.
A 22k won't load it down so it must be something to do with the IC or its supply pin feed.
So, not a lot to go wrong. Have you got +15? if you have a bad ground on the supply, it could be floating and still present +-15volts to the IC but as +22 -8.
Check the 10.8volts feeding the bias. That will tell you if the supply is not balanced.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Helmholtz View PostCheck C32/33/34 for leakage. What's the voltage at TP33? What does R53 measure?
Edit;
What has the secondary HT voltage got to do with the stated faultSupport for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Jon Snell View Post
Did you read the original post ... I think not.
Edit;
Now re-reading it seems to leave C34. - or excessive load current.
Didn't mention /refer to secondary HT voltage.Last edited by Helmholtz; 12-26-2023, 08:58 PM.- Own Opinions Only -
R53 measures -26.6vdc at the junction with c32. R50 has basically the same voltage at it’s junction with c30, however at other end of r53 there’s -8vdc where as r50 has 15vdc..Last edited by pontiacpete; 12-26-2023, 10:01 PM.
So something is pulling down the -15V line. Could be the zener, the cap, or anything running off the -15V (which seems to be only U1).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostSo something is pulling down the -15V line. Could be the zener, the cap, or anything running off the -15V (which seems to be only U1).
Supply X
Edit; This is why it is so important for the poster to identify the model correctly. We are all just guessing.
