Ill be doing cap job on a 1989 fender red knob twin. How should i approach the filter capacitor and powet resistor removal process without damaging the pcb traces?
What is the most safe method of desoldering filter capacitors from fender red knob twin pcb?
Take photographs showing details of wiring. This process assumes you are proficient at desoldering otherwise, take it to a person who is or get them round to yours for a hand.
You will render the ampifier useless with man made faults if you cannot desolder and solder proficiently.
Ensure the amplifier is disconnected from the mains supply and discharge the Grey and Blue large electrolytics.
Remove the fixing screws and lift the board to hinge out
Desolder and replace the capacitors only if they are faulty!
Do the same with the other components that are faulty.
The power resistors are ceramic wirewound and are either open circuit or OK.
NEVER replace components without the basic knowledge of how to test them correctly.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 5
It is recommended to use a solder station, one that allows you to control the amount of heat generated at the tip of the solder iron. When removing components, use only sufficient heat to "undo" the solder, to the point where you can loosen and remove the device lead from the trace. Otherwise, if you have a solder iron with "no" ability to control the heat, use it carefully and look closely to see when you reach the point of loosening the solder to remove the device lead.
I would also recommend you get yourself some type of desoldering tool, a mechanical pump type.It's not just an amp, it's an adventure!
These are the parts i will be desoldering and soldering:
Power supply section: (2) 47uf 350v and
(2) 220uf 300v
Preamp section: (3) 22uf
Bias cap: 100uf 100v
What else should be considered for further noise reduction and perfectly working amp?
https://www.amprepairparts.com/fende...s.htm#crossref
FCK-55Attached Files
I'd first do a quick ESR test on the caps in circuit. Also check resistors. As Jon said, there's no reason to just wholesale replace parts. Replace only parts that are defective. To do otherwise is a waste of time and money and could make things worse if you are inexperienced."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
If very much itchy hands and a great desire to change by their own efforts, and in the future to confuse the polarity when installing and break the device at all, then, first the parts must be separated from the silicone glue on the circuit board. Then bite out their leads. Then you can carefully unsolder the remaining pins.
- Likes 1
If those resistors are bad, you need to figure out why. They wouldn't go open without some serious current draw. If they aren't bad, why on earth would you replace them?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 3
Im buying a 35 years old amplifier which i believe will need to have a cap job at least and maybe some resistor swap. I will be receiving the amp in one month from now. I just want to order the parts that will need replacement.Attached Files
I've worked on a lot of these amps, with numerous different faults - but problems with the power resistors haven't been one of them. I wouldn't change them unless there's a fault - you unnecessarily risk damaging the amp or making a mistake.
The PCBs are no different to any other Fender PCB of this era. I have a desoldering station, which minimizes risk. For the many years before that I just used a soldering iron and desolder pump. Much damage is done to traces by heat-soaking the pad with an iron that is too small, underpowered or not hot enough. 'Hot and fast' is the way I work. X-pro's suggestion is what I would do in your position. Slice through the glue, cut the leads off and leave enough length to grab hold of. You can then quickly heat the joint and pull the lead through from the other side of the board. If necessary, remove any surplus solder afterwards with fluxed braid or a good quality desolder pump.
F&T caps are good, but so are Miec, which are very reliable.
Evaluate the amp first. Play through it, make observations and think about it before replacing parts that may be good. Whilst the grey Illinois caps in the Hotrod/Deville series are often high ESR or leaking/bulging, the caps in these amps hold up much better.
- Likes 2
Originally posted by Jquijano View PostIll be doing cap job on a 1989 fender red knob twin. How should i approach the filter capacitor and powet resistor removal process without damaging the pcb traces?
The #1 way to avoid damaging traces is to avoid replacing parts that are not proven bad.
You already know the traces are delicate. Don't take chances on damaging the board unless absolutely necessary. Think of the board as a component that is no longer available.
If you do have to replace a bad part, it is easiest if you cut the component lead off first, as was mentioned by x-pro and Mick Bailey above.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
You seem determined to just start replacing parts without doing any testing or assessing what the amp actually needs or doesn't need. This is NOT an effective or recommended repair process. All too often I've seen it result in causing more problems rather than less.
Edit: In fact, crackling noises may not require any parts. You could simply have connection issues. Or, you may have a bad tube. Just at a quick glance, I already see some areas that need to be checked, including some areas that may be damaged from previous work. Start by giving the entire thing a good lookover for solder issues before just throwing parts at it.
A = Possible cold solder joint.
B&C = Possible broken traces.Last edited by The Dude; 01-04-2024, 11:32 PM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
