Working on an all-original 1965 Princeton Reverb. Came in with one power tube not conducting and one alternating between no conduction and high current. Put in a new set of JJ 6V6S tubes and amp is working but tubes are pulling 35mA of current with 425V plate voltage, so over 100% of the 14 watt rating. Grid voltage is -35V, so in line with the schematic. Is this current to be expected with these voltages? Other than trying to order a special "cold" set of tubes is there anything I should be looking at other than adjusting resistor values to get a more negative bias voltage?
TIA,
Greg
TIA,
Greg
