Hello I have a problem here, this is a single ended dual power amp.
It has a rectified power supply for the ECC82 on both channels, both tubes share this filament supply.
The amp stopped making any sound and I traced it to the filament supply, reading only a mere 1 volt DC. Now, while I was taking some measurements, the filaments begun to glow and there was about 5.9 volts on them. The leads read correct continuity but to be really sure I have to unsolder quite a few cables and take out a board because the filament leads are soldered on the side I can't see.
What about the rectifier (one of those little round ones with four legs), or the filter cap?
Could they be the cause of the voltage drop?
Thanks for your help.
