Gday all,
I have the above amp here. Weak output. Essentially no i/p into the PI. All voltages are good and using the Service manual wave-forms are pretty much on spec as well up to the DFX card input Pin1.
I hate admitting defeat but I'm at a loss. Wondering if any of you Marshall gurus have come across these boards failing? Unfortunately the Service Manual doesn't give anything post DFX, just a test point into the PI (which is tiny). I"m hoping I'm just not seeing the forest for the trees, and its a simple/known issue, ( and I can handle the embarrassment)
Thanks
Gav
DSL40CR service manual (1).pdf
Thanks
Gav
