Schematic attached (scan from J. Darr book)
GibsonGA60.pdf
Amp output has -7.7Vdc on power up, slowly sinking to -0.4Vdc steady state. Running on light limiter with no load.
Transistor voltage measurements attached for Q5,Q6,Q7,Q11,Q12,Q3 and Q4
All transistors and diodes check ok with multimeter diode check. All resistors in output section check ok.
Looking for help in how to isolate and find the problem
GibsonGA60.pdf
