Hello,
I have a Super Reverb Reissue that has some mechanical vibration/microphonics problem going on (at least that's what I think it is). It only happens on certain notes (between the 7th and 10th frets on the wound strings, esp C and G) at higher volumes. What happens is when one of these notes is hit, a second tone is heard in conjunction with the first. It sounds like an electric razor or grinding metal, it’s just not as loud as the guitar note. But, it is very annoying and unmusical. I suspected the preamp tubes, so I replaced them all. It did not help. Then I took the chassis out of the amp and looked around. There didn’t seem to be any loose wires or bad solder connections, though I didn’t remove the board and look at the underside. I played through the amp with the chassis removed, and that seemed to have done the trick. This leads me to believe I have a microphonic component with something resonating nearby. It happens on multiple guitars, so it's not a fret buzz issue that is coming through the amp.
Has anyone dealt with anything like this? I'm open to any and all suggestions, because this is very baffling, and I need my amp for gigs.
