Hi all
I need help!
I am repairing, for a friend, an old Trace Elliot GP12 SMX 300W with a Bipolar Bear as Power amp.
The amp came with the Bipolar burned. It had most of the power transistors burned. I managed to find replacements (2SC4468 / 2SA1695, etc) and the power amp seems to be working now. I say seems because I haven't connected it to a speaker yet, only using signal generator and oscilloscope.
The issue is that during test I found that just a little of input signal is enough to drive the Bipolar to max power. Just having the Power Output level button up to 2 is driving the Bipolar Bear to max.
I check the pre-amp output where it connects to the Bipolar and the output voltage on max goes up to 4.5Vpp which seems to be fair.
On the Bipolar side, just injecting a 0.5Vpp sine wave signal (5KHz) at input is enough to drive the output up to 100Vpp. If I increase the input signal to 1Vpp the Bipolar output signal will start clamping and even the fan slows down. The wave form is correct.
I have checked the feedback circuit, even replacing long tail and current limiter transistors without success. As matter of fact at this point in time I have replaced ALL transistors in the Bipolar Bear, checked most of the components (resistors, Diodes, caps, etc).
What is going on?
Thanks a lot!
I need help!
What is going on?
Thanks a lot!
