This is a sister post to my prior thread on the JCM 800 “Pots and Replacements.” Different problem, different thread.
For this amp, there is something odd happening with the controls as they relate to operating Channels A and B. I cannot find a similar post or explanation anywhere.
The footswitch:
The footswitch contains two SPST switches with a TRS plug. I tested the switches and they work fine. (It would have been nice to have LEDs on the footswitch).
Test and operation with footswitch:
As I discovered, there is NO WAY to easily switch between Channel A and B. You must do that in two steps- Ugggg.
If I insert the guitar into the “Mix A & B” input, the amp is working as designed (and expected – I guess).
The starting state, with the footswitch buttons not depressed, neither channel lights up or works – I get that.
If you click on the “left” button, Channel B engages and the controls work fine - perfect
Click off of “B” and then click on “A” - Channel A works fine - perfect
If you engage both buttons, both Channels A and B turn on and they work together – perfect.
But as I stated, you cannot switch between Channel A and B.
Test and operate without the footswitch:
I plug directly into Channel A (and only the Channel A LED is on), the controls for “A” work fine. While still plugged into A, if I change the Channel B controls, they do not impact what is happening with Channel A. All good.
The problem – If I plug directly into Channel B (and only the Channel B LED is on), the controls for B work fine. BUT… if I change the Gain level on the Channel A, that changes the volume on what is happening with Channel B. So there is some type of cross interference here between the channels.
I am looking at the jacks inside the chassis. Channel A and B are mono jacks. The Footswitch is a stereo jack (and there are 6 pins going into the PC board as designed). The Input Mix A & B is a stereo jack. And from the looks of the schematic, one side of the jack is grounded while the tip is the only one that gets the guitar signal? And this is where the footswitch engages A, or B, or both?
I am stumped over the problem of going directly into Channel B but the Gain control in A changes the volume of B.
Any ideas on what to look for and thanks in advance!
The footswitch:
