Looking at the output side of the RLC filter, I see the 350 kHz due to the PWM is still partially present. Is it normal for a small amount to remain? See pics below. The same noise is present on both the plus (yellow) and minus (purple) side, so I suppose you could consider it common mode noise that the speaker doesn’t see since it looks at the difference between + and - (white) But I wonder if the filter should do a better job of removing the high frequency component. Thanks for any insight.
Peavey Max 115 300W
I've gotten used to seeing that with many class D amps. When on both output terminals like that, I consider it normal. Once the speaker is connected I never hear any adverse effects.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
The output chokes remove most of the HF but some will still remain. Even on the best quality Hi Fi amplifiers, there is always some remaining.
The speaker lead is a capacitor and that will smooth out most of the remaining but your loudspeaker, however 'good' it is, will not reproduce any of it, if it could, we won't hear it anyway so not worth spending any time on it.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
