Originally posted by Helmholtz
View Post
Framus Ruby Riot 2 blowing mains fuse
Could be a problem with the rectifier tube.
Pull the GZ34 and try again.
BTW, I just saw that the first filter cap is 220µ/350V. Way too large capacitance for a GZ34, especially with hot-(standby-)switching as used here.
GZ34 limit is 60µF. Also a 350V cap rating is too low. What a poor design!]
Originally posted by Helmholtz View PostPlease answer post #15.
V1a=196v, V1b=254v, V2a=241, V2b=332v
Yes, but I recommend to also replace C19 (220µ/350V) with 68µ/450V.Last edited by Emetal; 03-30-2024, 12:33 AM.
Yes, that is fine. A "cement" resistor is a wire wound resistor. 11W is fine, but 10W should be more readily available and cheaper. Surprised you can't find them. Here, for exmple:
https://www.digikey.com/en/products/...1068RJ/2365737
- Likes 2
Originally posted by The Dude View PostYes, that is fine. A "cement" resistor is a wire wound resistor. 11W is fine, but 10W should be more readily available and cheaper. Surprised you can't find them. Here, for exmple:
- Likes 1
OK guys, rectifier tube GZ34 came in, installed, everything works, I could take the amp off the limiter bulb plug in normally and play. Well, then I did suggested improvements, changed C19 to 68uF/450v and R82 to 68R/11 watts and I think there is a problem, as soon as I turn on the Stand By switch, bulb limiter lights up and STAYS lit very bright! That's not good ha? Bulb should light up and then gradually go down right?
Originally posted by Emetal View PostI think there is a problem, as soon as I turn on the Stand By switch, bulb limiter lights up and STAYS lit very bright! That's not good ha? Bulb should light up and then gradually go down right?
I expect the amp to draw a lot of current, so a low wattage bulb will light up.
What wattage is the light bulb?
Originally posted by Helmholtz View Post!00W is not low wattage, so be careful.
