Peavey 5150 LED Bezel
  • Peavey 5150 LED Bezel
    I've scoured the web. Peavey apparently no longer stocks them. So, I'm looking for a source for the LED bezels in a Peavey 5150 head. Posting a picture I found on the web for reference. TIA!
    Click image for larger version  Name:	medium_preview_Peavey_LED_Bezel_3.jpg Views:	0 Size:	5.1 KB ID:	997009
    The lawyers had Peavey literally destroy anything with the EVH logo after their falling out.
    Good luck.
      Gotcha. Even so, these bezels are used in several other Peavey amps. I've been able to find out that the Peavey part number was 70450586. I've also found that Jameco part number 95521 and Conxrite LMH100 will work. Unfortunately, I've not been able to find a supplier of any of these.
        I think I scored! Ordered these. I'll report how they work when they get here.
        https://www.digikey.com/en/products/...RUgcgCIgC6AvkA
          Well, that was a bust. The bezels came in today and are too small. I read on a few blogs that the LED's were 2x5mm, so didn't measure. That was my error. The LED's in the 5150 are 2.5x5mm, after measuring. So, the short of it is that the bezels I got don't work. They are too small and fall right through the chassis holes. So, the hunt continues. I can no longer delete the link in my post above, so if any mods read this, can you please delete that link so that nobody else makes the mistake of ordering those?
            That sucks. Do you have access to a 3D printer? Found this while searching.
            https://www.stlfinder.com/model/2-5x...zXxb1/3212050/
              I found that, site too. Unfortunately, I don't have access to a 3D printer. I couldn't wait on this amp and hold it up for a silly bezel, so I carefully glued the broken ones together (I still had most of the pieces) and kicked it out the door. I'd still like to find a source for them, though. I'm sure this won't be the last time I need them.
                can you fill the hole with back epoxy? what size is the hole?
                  The amp is already gone. Customer needed it for a gig, and the bezel is purely a cosmetic thing. I'm sure there are numerous ways to "approximate" the look, I just thought it would be nice to find an actual part, if one exists. Thanks everyone for chiming in to help!
