Just wondering if anyone has worked on at least one of these over the years.
Re-furbing one of these, got pretty much everything sorted out, new filter caps, output tubes etc.
The schematic has 6L6's for the output tubes, this one had 8417's, possibly just thrown in by someone or did these come with anything other than 6L6's?
Bias voltage was really low, only -40v at the source with about -20 at the tubes. I did replace bad bias filter caps and bad/leaky PI coupling caps, but bias was still the same so I added a doubler circuit.
I'm going to swap out the 2.7K bias ground with a 10K pot for better adjustment.
Somebody had removed the output tube cathode resistors, I'm trying to decide whether to use one or ten ohm resistors for easy bias measurement.
Power was also low, one problem being the 10K high voltage dropper at B3 was replaced with a 39K
The other was the 7247 phase inverter was replaced with a 12AX7.
I don't know why they elevated the heaters, seems like overkill.
So it's nice and quiet now, putting out about 50-60 watts
