I'm a bit confused by the following problem. I have 2 Marshall JCM 900 100 watt Hi gain dual reverb amps here. One came in with the main fuse blown, the other just needs the reverb fixed.
Amp 1 that blows the fuse I've removed all the secondary wires on the power transformer, have all power tubes removed, yet stills draws high current, almost 1 amp at only 5% or so on the variac. I have to remove one of the red "jumpers" on the primary side of the PT to have that rapid rise stop and rise slowly as normal. When I measure the resistance between the outside terminals on said transformer, and compare them to the amp that works, I actually get higher resistance than the working amp. i.e. 2.9 ohms vs. 1.8 ohms on the working amp. Main primary terminals. Similar readings on all other terminals. I can find no short to ground or other low resistance readings anywhere.
![Click image for larger version
Any thoughts much appreciated!
