I'm presently servicing an Ampeg SVT4-Pro that has significant distortion in the Vactec-based Limiter in the front end of the Power Amp Circuit. It uses a Vactec VTL-5C7 in the feedback loop around an inverting 6dB gain stage ahead of the op amp that drives the output stage. The LDR portion of the Vactec is switched in using a J176 P-Ch FET. When I turn the limiter off, allowing the amp to clip, it sounds fine, other than you can drive it into clipping. With the limiting stage in circuit (normal operation), it's preventing full output and does appear to be where the distortion is occuring.
I just ordered replacement TL074 op amps and replacement J176 P-Ch FET's, but can't find any source for the Vactec VTL-5C7 anywhere. I haven't yet contacted Yamaha to see if they're still using that Vactec in the power amp stage (it's also used in the compressor circuit.
Power Amp PCB Schematics (428xxh0_).pdf
VTL5C6, 5C7.pdf
VTL5C3, 5C4.pdf
Anyone know a source for the VTL-5C7? I do have a few VTL-4C4's on hand.
VTL5C6, 5C7.pdf
VTL5C3, 5C4.pdf
