Another Burns of London, Amplifier on my bench for repair ...
If you can't fix it, I probably can.Tags: None
- Likes 2
The stated fault is poor sound and crackling selector switch.
First inspection shows aged electrolytics , mainly 100u 10volt and 470u 25volt with a couple of 5u 10v and a 1u 5volt.
All three large capacitors measure perfectly fine with no sign of any issues, no measurable leak and all three have an ESR reading of less than 1 Ohm.
Fresh capacitors fitted;
The few old types that are still in circuit decouple the emiters of the pre amp germaniums and are in good condition.
More to follow ...Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Helmholtz View PostAs the early Ge transistors could be damaged by heat during soldering, they came with long leads and not shorting them was a precaution.Transistors were expensive then.
I use a pair of flat bladed pliers and a hot soldering iron for speed.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Jon Snell View Post
Indeed, a heat sink is required when changing/soldering Ge transistors.
Originally posted by Helmholtz View PostAs the early Ge transistors could be damaged by heat during soldering, they came with long leads and not shortening them was a precaution.Transistors were expensive then.
- Likes 1
This amplifier employs NKT403 output transistors, transformer couple to an NKT404 running from a stabilised 32volt DC supply. NKT = Newmarket Semiconductors.
The pre driver is an NKT213 and another NKT213 with an OC702 pre amp.
Surprisingly quiet, noise wise and the replaced leaking capacitors, have stopped the nasty crackling noises from the selector switch.
Some snippets of how they put it all together and what the various parts do.
Sounds exactly as I remember these with the Elac loudspeakers. One of the plastic magnet covers was loose and I had to glue it back on, taking a photo of the makers name first.
Another great piece of history up and running again in our local recording studio.
Thank you for looking.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 5
