I serviced a 1960ish Gibsonette. Had a hard time finding the matching schematic. This amp has 1 volume pot, a 12AX7 preamp tube and a choke (which I think is a field coil choke).
I think this amp may have originally had a field coil speaker and a 6SJ7 preamp tube.
It had very loud 120 cycle hum when brought up slow on the variac. I replaced all the filter caps and resistors. After which I had a background 120 cycle hum.
I ended up re-wiring the filtering section per for following GA-8 schematic. This included removing the field coil choke from the circuit and adding an additional filter stage.
The only difference I could see between the GA-8 schematic and this Gibsonette is the GA-8 has a tone pot.
The amp was returned to me and I can see that the added filter stage 2 watt 470 ohm resistor has been cooking. Seen in the center of the below pic (below the blue filter cap).
I also found the following schematics. First shows an "un-valued" resistor where I have the 500 ohm (really 470 ohm) 2 watt.
So I had a bunch of confusion on what schematic to use and why the field coil was still in circuit. Anyhow, what do you think of the changes and why is the 2 watter cooking? Do I just need to use a 5 watt or could there be other issues to consider?
Thank you
Thank you
