I have 5F6a that built. I set the bias using the transformer shunt method.
I set my meter to milliamps and measure one side of the output transformer. Even after the amp has warmed up the bias drifts between -36.1mA and -34.8mA. It 's never steady. I do use a zener diode on the PT center tap to drop voltage. I have replaced the bias supply power resistor, diode and filter cap. The cap is 100UF 100V. Checked connections with a meter and connections test good. Used different tubes. Amp works fine. I'm wondering if the power transformer or zener diode are bad . What could be my problem??
Rymac
Rymac
