I know, right? Another HRD with switching issues. I've read through most everything I can find and I haven't found anyone with this issue yet. Hopefully it is something obvious to someone more experienced.
I've changed the typical low voltage supply parts, caps, resistors, zeners. But that was prior to getting the amp in a state that I could test the switching. So, unfortunately I don't know if I caused the issue or not. I'm generally tidy, and neat and careful with my work, so I don't think that what I did is the issue.
Anyhow, getting to the point. Clean to drive works fine, but drive to "more drive" doesn't work. The LED goes off entirely, and actually switches back to the clean channel. All the test point voltages seem correct or within reasonable tolerance based on the schematic notes for the TP's. -15.86v instead of -16 for instance. Only thing left to test that come to mind are the J111 FETs, the relay, and the LED itself.
Just odd behavior and was looking for any thoughts while I continue poking around to try and understand why it would behave that way as I'm somewhat of a novice.
