I have an Ampeg J-12T (reissue, not vintage) that I like a lot, except for the lack of a footswitch to control the tremolo function (which sounds great). Basically it has speed and intensity controls, if you don't want tremolo, you turn the intensity down...there's no switch at all. Pretty useless for a live situation, unless you want the same amount of tremolo for the whole song...I would be happy with a regular on/off footswitch like fenders, or I was thinking I could drill a hole in the chassis and put in a female 1/4 jack, I guess it would have to be a stereo jack, right? Then I would connect the two terminals of the intensity pot to the jack and use an expression pedal in place of that pot? Would this work?
I'm really not an expert on this stuff, but I've tinkered around a bit...the schematic says the pot is 1M audio single...so I guess that means I would need a volume/expression pedal with that same resistance, right?
Any help is appreciated...
