Heres the mod-
"A very simple MOD to the AOR100 is to simply remove R6 and R7 100K resistors and replace with a single 470K. Replace VR-1 100K POT with a 1 MEG POT, if you cannot find a replacement push/pull you can add a toggle on the front or back panel."
Ive circled what I believe is the VR1.(Also located a replacement 1 meg push/pull pot.) Its the Pre amp volume one with pull to activate the AOR gain. Cant seem to ID the 100K R6 and R7 resistors. Any help with this mod would be greatly appreciated. Bob
