I've tried combining an el84 with a 6v6 in a two tube PP output stage (both cathode bias) and while the result is interesting there is way too much fat. Coupling caps to the outputs are .002. there is no tone stack.
As an experiment I tried running the the 6v6 in triode mode (pins 4&5 connected through a 100k resistor and the result seemed more along the lines of what I wanted. The thing is there seems to be some sort of quiet ratty distortion as the signal dies out. No doubt from interaction of the odd combination of triode and pentode. What else would one need to consider to continue in this direction?
