I understand (from a previous post of mine) a common method involves connecting jumper wire from the chassis to pin 3 of a power tube. Just wondering what type of cable is acceptable and what type of insulation on the cable as well as the alligator clips. I can picture draining these caps generating a lot of heat and want to be absolutely sure that the insulation holds up! Also, would it be worthwhile to connect a power resistor in the middle of the cable? If so, what specs?
I am on the mouser site now ordering parts for a mod that Chuck H recommended me and figure I may as well order parts for the filter cap draining.
thanks,
brian
thanks,
brian
