Originally posted by jrfrond
View Post
Draining Filter Cap Question
I don't think there is anything wrong with John's method either.
I do the same thing with my signal gen when working on my bench.
The real downside is that the tube amp must have hot vacuum tubes in order for them to work and drain off the B+ rail.
If you flip an amp on and off too fast, the rectifier will charge up the hi-voltage caps instantly if solid state (and very quickly with a rectifier tube)... but the other tubes might not heat up and will not conduct!
So then the filter caps do stay charged up and can give you serious poke.
Just respect that and the method John is stating is fine most of the time.
Originally posted by jrfrond View Post.....And, like I said, I ALWAYS double-check when I open the amp with my DVM, and you (meaning everybody) should too!
Use your head, and you'll get to keep it.
Originally posted by boyt_bpc View PostIt sounds like the common knowledge is "It works" but the mantra in learning is "Don't do this."
Originally posted by jrfrond View PostI've been repairing and building amps, guitars and drums for 30+ years. I'm involved in electronics, woodworking, metalworking, finishing, power tools (some potential very dangerous) and I have made and gotten away with more stupid and dangerous (personally) moves than I care to count. I don't advocate the use of dangerous practices, but every experienced tech does it, and occasionally pays for it (a few with their lives). This is why I recommend the DVM-backup approach to ANY method of cap discharge, whether it is my down & dirty method, or the bleeder resistor approach. I was once on the receiving end of a paramedics' defibrillator paddles from a massive shock when I first started in this business, and now have a healthy respect for electrical current. You should too. THAT is the proper school of thought.
The bottom line is we want to empty our caps. Whatever method you chose, if it works and you check with a meter, then IT DOESN'T MATTER WHAT THE METHOD IS. We can endlessly debate whose method is "better," but if it works it works. The fact that someone like John seems comfortable doing it doesn't detract from its efficacy. I may seem nonchalant doing my benchwork as well. Doesn;t mean I am not aware of the safety issues, they are part of my routine. I feel a lot safer relaxed and confident in my approach than being all tense, uptight, and fearful.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe bottom line is we want to empty our caps. Whatever method you chose, if it works and you check with a meter, then IT DOESN'T MATTER WHAT THE METHOD IS. We can endlessly debate whose method is "better," but if it works it works. The fact that someone like John seems comfortable doing it doesn't detract from its efficacy. I may seem nonchalant doing my benchwork as well. Doesn;t mean I am not aware of the safety issues, they are part of my routine. I feel a lot safer relaxed and confident in my approach than being all tense, uptight, and fearful.
