Over the years I’ve had a lot of success with opamp substation in hifi equipment so I thought my Peavey MX-VTX [SS preamp, 6L6OP] would be a good candidate.
I replaced the 5 x 4558’s with OPA2134’s and got mixed results.
If I played gently, they sounded much better: quieter and cleaner with a more open “valve-ish-ness”
However, when I dig in there is an unpleasant distortion/sag effect.
It seems transient: Following the “pick” attack [as the note fades] the distortion goes.
The power supply in this amp uses basic zener regulation that requires 250 ohm resistors in each of the supply rails.
Also, there are no filter+filter bypass caps mounted close to the supply pins on any of the op amps.
I suspect the OPA2134 opamp does not like this supply arrangement, I tripled the filter capacitance and got a very noticeable improvement, but the problem still persists. .
For the gain in sound quality, I think the substitution is worth persuing.
I could do either or both of the following:
1. Replace the supply with fixed regulators.
2. Create 5 plug in DIL boards with OPA+ low ESR filtercaps
Electronically, this is straightforward, but mechanically and geographically these things are always more challenging.
So just wanted, some opinions and suggestions before make the final decision.
Cheers
Cheers
