Statesmen-
I come before you with the following regarding ghost notes in my recently-acquired and recently de-modded 1994 Matchless HC-30:
Facts: Had an experienced (retail!) amp guy in Dallas retube and de-mod it – he worked with Matchless to return it to original specifications using parts from Matchless including three 22mF 450V SAMHWA caps, three 33mF 450V BMI caps, one 250 mF 100V BMI cap. Ruby tubes in triode channel are super quiet and musical and I’m still plumbing the excellent sound of that channel.
Frustratingly, however, I now plainly hear 120hz-induced ghost notes at medium or high volume settings (e.g., 293.7 hz brings along ~123.5 hz – the usual 60/120 sneaking through). Same result regardless of cabinet, output tubes, recto tube configuration, channel, run time, instrument, polarity switch, etc. On low power setting, there’s less ghosting but it is still noticeably present.
Opinion: Tesla’s gift of alternating current does present challenges for an amp design featuring sag, but ghost notes in a fine instrument are unacceptable, period (especially in an amp that sounds this great in all other aspects).
Goal: Rather than sell the amp, I’d like to improve the design and arrive at the same sound (same sag, squish, etc.) – just void of ripple. The message I’m getting is that the Matchless is indeed built like a tank on the inside too – it is not altogether elegant and can be improved in certain respects, with filtering and isolation being notable examples. Can’t get any of the amp techs I know to show excitement about the undertaking. I think they’re getting stuck when I say “I don’t want the sound changed noticeably – just nix the ripple”.
…so,…
Petition: I humbly request some replies to this email containing artful “success stories” or specific instructions regarding removal of 120hz ripple from this amp or a similar one. So that I don't have to expose my current paucity of amp savvy, please assume the amp is brand new and all parts are running to spec (I played a neighbors' brand-new unnamed nice/expensive boutique 2XEL84 amp on Holloween - ghostorama - Poltergeist, even - so new amps apparently aren't immune).
I’m attached a pic of chassis if that will help.
Thanks. I'm jealous of all of you amp geniuses.
…so,…
