I built a bassman 20 recently with the power supply from the deluxe reverb ab763 circuit using a deluxe trafo and the bias supply set up with the adjustable pot and a standby switch. I'd like to change out the tube rectifier(gz34) and put in a bridge rectifier but I'd like to keep the adjustable bias supply. I'm having a problem figuring out the wiring. I've tried clip leading it in on a breadboard and haven't had any luck.
Is there anyone here that could help be with this?
thanks in advance.
pete
thanks in advance.
pete
