New Month We are at $0 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
For typical Boss FX, I'd put it before R14, right after the Volume pot.
The bubble in the schematic identifies the level as 180mVAC feeding the volume with 25mVAC in. That's a voltage gain of 7.2. You might like a small divider before the FX loop, but it's a level that the FX input pot should handle.
The second one is WAY too strong for a stomp pedal. (7VAC before R17). I hadn't seen the schematic before today, but it's odd to see a Fender tone stack with no pots. I feel some experimentation coming on...
I did it before R14 but the amp oscillates like mad (red plating and all)
Low frequency I guess: lots of distortion and very little sound power in the speaker.
Does it oscillate etc when a FX unit is plugged in or not?
I could be wrong about this, but shouldn't you have a blocking cap between where you've tapped off your return circuitry and the grid? (to stop grid current and/or DC from the FX unit upsetting the grid bias of that following stage?). Also do you need (something like a 1M) Grid bias reference there (because you are now dealing with a return signal from outside the amps own circuit and you need to watch your impedance bridging?) JM2CW (These are just my off-the-cuff hunches)
The amp squeals even with no FX plugged in. I've used shielded cable all over the circuit.
