A customer brought in this amp because he has fryed 3 Celestion vintage 30's.The amp is a 100wt combo,1X12.He said after a tube failure LED came on he replaced the output tubes,and started frying speakers.So I checked the screen grid resistors(2.2K)-1 measured 2.0k the others are 2.1k-The solder joints looked as thought they had been getting real hot,looked grainy.I suspect the OT,having read that Marshall OTs can be somewhat delicate.As an initial test I plugged in to the speaker output and it tests as shorted,but so do working amps.A resistance reading is .0-I have yet to try the current limiter to test for a short,and have found a test method using a 6.3v transfromer.
This amp belongs to a touring muscian and is a part of his signature sound.He has opened for ZZ Top,played with Mark Farner,Rick Derringer,Matt "Guitar" Murphy,this is a hard working amp.If a replacement is needed do you recommend an original replacement ,or maybe a Mercury Magnetics for improved sound and reliability.I have no experience with them and want to do right by this guy.
