Well its not that I'm afraid to do it or anything. Its just that I take out the chassis for my Carvin X100b anyways to do a bias. So I'm kind of used to it.
VK112 Bias Pot Mod
Originally posted by pburgbahamut View PostWell its not that I'm afraid to do it or anything. Its just that I take out the chassis for my Carvin X100b anyways to do a bias. So I'm kind of used to it.sigpicCharlieP
(2)Peavey VK 112 2008
Fender SuperSonic 60W 112 2010, 5E3 Build Mojotone
Met. Red LP Gibson Robot 2008 Tronical Tuners
Faded Cherry LP Gibson 2007
Fender Strat HSS LSR S1 2008 Pearl
Fend FSR TelebotDlx Candy App 2011 Tronical Tuners
Gretsch G5120 2007 Black
Just an update here! I acquired my second VK112 and did a mod to it. This time I used (2) 6.8K resistors. One in and one out in series path. Used the same Weber 50K Bias Pot as the first time. Using two resistors was just a convenience of attaching. Last time I used (1) 15K resistor and for the second path connection I had soldered (2) clipped resistor leads together to bridge the connection from board to pot. I felt that may create a future fail point with vibration.sigpicCharlieP
Originally posted by docz View PostDid you have to take out the PCB to access the solder points? Or did you just top solder them?
DocZ
Warning: Do not attempt this unless you fully understand how to discharge caps. High voltage and dangerous.
sigpicCharlieP
Updating a bias pot that is 25 K from Weber WP253-slot-lock. Use of the 25 K will give you a better range of adjustment.sigpicCharlieP
Just curious what're the plate and screen voltages after adjusting for a "hot" bias, people seems to prefer running the 6L6s that way in the amp.
Found a part of the answer on this old post - the voltages before any "hot" bias adjustment is made.Last edited by jazbo8; 08-12-2014, 03:39 AM.
