I have a question I would like to ask to try to help out a friend...He has a Fender Hot Rod Deluxe and a fat Squire playing lead. He tells me the amp sounds best at a certain volume level and the sound quality is not the same if it is lower, the problem is at certain locations the output is too much and he would like to be able to keep the amps volume level setting where he likes it. So he uses a blanket over the speaker grill to quiet the output (no it's not blocking ventilation flow)
Anyone have any tips or tricks he could try to get sound levels to lower volume and keep the sound quality he needs ??
Thank You,
Thank You,
