Is there anyone have an idea or schematic for adding reverb to a plexi style circuit.I had rewired my JCM 800 4211 combo to a plexi 1959 , so i have aready my reverb tank ,transformer and 2 free holes for extra tubes.
Hey , it worked. Here's the 2040 schematic as well.
V3a is the delay line driver, V3b the recovery amplifier. 1M pot on V3b is reverb depth.
The input is from the 0.047uF cap after V2b, the output comes from the 470K resistor after 1M reverb pot wiper. The 1M resistor mixes dry signal with the delayed signal. To bypass the effect, short the grid of V3b to ground.
Tubenit
I wonder why you've drawn a 220k in between R1 and R2 in this case. If I remember correctly you've drawn 100k resistors in your other schematics.
Is there a reason I don't get?
BTW I will definitely use your kind of reverb in my next build.
That schematic just happen to have that value in it. I think my builds actually have 100k-150k values and usually 100k. Any of those values will work though.
Yeah, I thought so. Compared to the fender value of 3.3M in most cases, either the 100k or 220k wouldn't make a big difference. I believe that the way with a 100k resistor would attenuate and damp the signal much less (than 3.3M) and therefore leave the sound more like a preamp with no reverb. Good thing IMHO. Although I haven't tested it yet.
