Hi,
As probably most of you know if you plug a cable in the PreAmp Out of a Hot Rod Deluxe it works like a split capable to send the sound somewhere else but the internal connection with the power amp keeps working unaffected.
What really defeats the connection is plugging a jack in the Power Amp In.
What I would like to do is to add a switch to remove this "internal connection defeat" function if I want, allowing me to add a 100% wet delay output while the dry sound remains untouched and still travels inside to the power amp.
The reason i want to do so is because I love my Eventide Timefactor which allows a "killdry" function for full wet output, but despite the high quality I don't like what it does with its buffer if I use it in relay bypass mode (that also has the drawback to cut the delays when the unit is switched off) and even less to keep the signal constantly digitized if i use it in dsp mode.
In another amp, a 5e3, I used it very nicely grabbing the guitar sound from one of the secondary inputs and sending it to the other input, i also have independent volumes...I think that having the possibility to use the preamped signal in the hot rod's fx loop is even better, but only the way I described above.
Please enlighten me on what could I do. I don't care if I have to mod heavily the hrd, it's already very modded and really kicks, so...
Thanks.
Thanks.
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
