Hey all, got a quick question - don't know if anyone here knows the amp, but I just picked up a Peavey "Rock Master" head in a trade. Not to be confused with the newer Rock Master preamp, this is a stand-alone head with 4 x 6L6GC power tubes and 3 x 7025/12AX7 preamp tubes. 120W output at 4ohms, according to Peavey.
I'm wondering if I can pull the two outside power tubes to run at half power? I know the volume won't drop much, but I'd like a bit more "fullness" out of the amp. The amp wants to see a 4ohm load, so with two tubes pulled I should be using an 8ohm load, correct?
The output transformer in this amp is huge (in my opinion, of course, this is my first 100+W amp) and I know older Peavey gear was built like tanks, so I'm not too concerned about stressing it. I'm sure Peavey designed this thing to still work if, say, plugged into an 8ohm cab instead of 4ohm. I'm just not sure if there's anything funny about the power section that would prevent me from pulling tubes - I assume it's running a parallel push-pull output like most quad 6L6/EL34 amps, but I don't want to pull tubes until I'm sure.
If anyone has a schematic for this amp, I'd appreciate it - I plan to tweak it in the future, but for now I just want to get used to it as-is.
Thanks if you can offer tips or advice!
Attached a picture - yes, I've got the cabinet as well, just pulled the chassis to clean it - tubes look like all-original Peaveys, and the dust in there made me think it's never been opened before!
