Hey, anybody ever mod an ampeg vt-22 or vt-40 with an adjustable bias pot? I've got a 71' vt-40 toploader and a distortion circuit vt-22. I've recently aquired both of these amps and am going to do caps & tubes to bring them up to speed. I've worked on fenders and marshalls, but I just don't have any experience with to many ampegs. I know ampegs are just a bit different and I don't want to blow it up. Any help would be great. thanks, sean
Bias pot mod for ampeg vt-22 & vt-40
It's pretty easy to do. You replace the 75K resistor in the bias circuit with a different value resistor and a linear pot in series. For example...a 56K resistor + a 25K linear pot. Start the amp up with the pot turned to max resistance, and then adjust your bias from there.
Originally posted by Diablo View PostIt's pretty easy to do. You replace the 75K resistor in the bias circuit with a different value resistor and a linear pot in series. For example...a 56K resistor + a 25K linear pot. Start the amp up with the pot turned to max resistance, and then adjust your bias from there.sigpicCharlieP
(2)Peavey VK 112 2008
Fender SuperSonic 60W 112 2010, 5E3 Build Mojotone
Met. Red LP Gibson Robot 2008 Tronical Tuners
Faded Cherry LP Gibson 2007
Fender Strat HSS LSR S1 2008 Pearl
Fend FSR TelebotDlx Candy App 2011 Tronical Tuners
Gretsch G5120 2007 Black
