I just aquired one of these and after some minor tweaks it works fine but I have some questions.It is a Revision B version
1.It came with a peavey 2 button footswitch without leds,I opened the footswitch and held an led across the switch terminals and it will light up when the switch is activated but I can hear a relay clicking in the amp,can I install leds on the footswitch?
2.At the Boogie Board many advise a master volume mod-remove a 220k resistor that bridges the middle leg to one of the outside terminals.I tried it but the lead channel seemed to sound snarly after so I returned it to stock.Does anyone have any advice maybe use a different value resistor?
3.Some folks have swapped a Mercury Mag OT with excellent results,any other recommended tranys? How about an AC30 OT?
Thanks for any Ideas-Kevin
