Not quite keeping up with the Hot Rod Deluxes and Vibratone, etc., at the local open mic jams.
Good tubes. Works fine...just not quite enough clean balls. Running volume on Vibrato input about 8-1/2, Treble on 7-8, and Bass about 4-5. Any more on the Bass gets woofy.
Effects are Dunlop Hendrix Wah>Tube Screamer>Boss DM2 Analog Delay. Last week I added a DOD 250 OD/Preamp to the end of the chain to try to goose the input of the amp a bit more with Level about 80%, and the gain brought up as little as possible, about 30%. Helped a little, but still not quite there. Plus, it just amplifies any effects hiss. The Tube Screamer sounds OK when it's on, and adds enough with the level to keep up, but I need some clean, and to leave the Tube Screamer set where it is when I kick it in. May try putting the DOD pedal right after the Tube Screamer, and using them separately, but I'd rather just leave it out. So, I had another thought.
Before I go through the trouble, would like opinions on whether changing the stock Jensen C12K to an EVM12L I have lying around might be worth a try?
Not much difference in published sensitivity:
C12K=99.1 dB
EVM12L=100 dB
Frequency response:
C12K=70Hz -7kHz
EVM12L=80Hz - 5khz
Resonant Frequency:
C12K=~107 Hz
EVM12L=~55 Hz
Anyone try an EVM12L in a DRRI? Good? Bad? Indifferent?
Thanks,
Brad1
C12K=99.1 dB
EVM12L=100 dB
Frequency response:
C12K=70Hz -7kHz
EVM12L=80Hz - 5khz
Resonant Frequency:
C12K=~107 Hz
EVM12L=~55 Hz
Thanks,
Brad1
